MPICH/MadIII: a Cluster of Clusters-Enabled MPI Implementation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
This paper presents an MPI implementation that allows an easy and efficient use of the interconnection of several clusters, of potentially heterogeneous nature (as far as the network is concerned). We describe the underlying communication subsystem used. The mechanisms within MPI that inform the user of the underlying topological structure are detailed. The performance figures obtained with this MPI implementation are discussed and advocate for the use of such a solution on this particular type of architecture.
CCGRID.pdf (513.24 Ko) Télécharger le fichier
article.pdf (92.94 Ko) Télécharger le fichier
hal-00344362 , version 1 (04-12-2008)
Guillaume Mercier, Olivier Aumage. MPICH/MadIII: a Cluster of Clusters-Enabled MPI Implementation. Third IEEE International Symposium on Cluster Computing and the Grid (CCGRID'03), May 2003, Tokyo, Japan. pp.26--35, ⟨10.1109/CCGRID.2003.1199349⟩. ⟨hal-00344362⟩
Collections
CNRS
230 Consultations
312 Téléchargements
