On the total order of reducibility of a pencil of algebraic plane curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2008
Laurent Busé
In this paper, the problem of bounding the number of reducible curves in a pencil of algebraic plane curves is addressed. Unlike most of the previous related works, each reducible curve of the pencil is here counted with its appropriate multiplicity. It is proved that this number of reducible curves, counted with multiplicity, is bounded by d^2-1 where d is the degree of the pencil. Then, a sharper bound is given by taking into account the Newton's polygon of the pencil.
HomRup.pdf (273.81 Ko) Télécharger le fichier
hal-00348561 , version 1 (19-12-2008)
hal-00348561 , version 2 (17-08-2011)
Laurent Busé, Guillaume Chèze. On the total order of reducibility of a pencil of algebraic plane curves. 2008. ⟨hal-00348561v1⟩
480 Consultations
183 Téléchargements
