Enumeration of Pin-Permutations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2008
In this paper, we study the class of pin-permutations, that is to say of permutations having a pin representation. This class has been recently introduced in an article of Brignall, Huczinska and Vatter, where it is used to find properties (algebraicity of the generating function, decidability of membership) of classes of permutations, depending on the simple permutations this class contains. We give a recursive characterization of the substitution decomposition trees of pin-permutations, which allows us to compute the generating function of this class, and consequently to prove, as it is conjectured, the rationality of this generating function. Moreover, we show that the basis of the pin-permutation class is infinite.
RationalityOfPinPermutations.pdf (371.43 Ko) Télécharger le fichier
hal-00348664 , version 1 (19-12-2008)
hal-00348664 , version 2 (05-03-2011)
  • HAL Id : hal-00348664 , version 1
Frédérique Bassino, Mathilde Bouvel, Dominique Rossin. Enumeration of Pin-Permutations. 2008. ⟨hal-00348664v1⟩
Collections
LIAFA
536 Consultations
260 Téléchargements
