Conditional extremes from heavy-tailed distributions: An application to the estimation of extreme rainfall return levels - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Extremes Année : 2010
This paper is dedicated to the estimation of extreme quantiles and the tail index from heavy-tailed distributions when a covariate is recorded simultaneously with the quantity of interest. A nearest neighbor approach is used to construct our estimators. Their asymptotic normality is established under mild regularity conditions and their finite sample properties are illustrated on a simulation study. An application to the estimation of pointwise return levels of extreme rainfalls in the Cevennes-Vivarais region is provided.
knncovar3.pdf (850.18 Ko) Télécharger le fichier
hal-00371757 , version 1 (30-03-2009)
hal-00371757 , version 2 (22-09-2009)
hal-00371757 , version 3 (07-12-2009)
hal-00371757 , version 4 (23-04-2013)
Laurent Gardes, Stéphane Girard. Conditional extremes from heavy-tailed distributions: An application to the estimation of extreme rainfall return levels. Extremes, 2010, 13 (2), pp.177-204. ⟨10.1007/s10687-010-0100-z⟩. ⟨hal-00371757v4⟩
518 Consultations
536 Téléchargements
