Conditional extremes from heavy-tailed distributions: An application to the estimation of extreme rainfall return levels - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2009
This paper is dedicated to the estimation of extreme quantiles and the tail index from heavy-tailed distributions when a covariate is recorded simultaneously with the quantity of interest. A nearest neighbor approach is used to construct our estimators. Their asymptotic normality is established under mild regularity conditions and their finite sample properties are illustrated on a simulation study. An application to the estimation of return levels of extreme rainfalls in the Cevennes-Vivarais region is provided.
knncovar2.pdf (963.71 Ko) Télécharger le fichier
hal-00371757 , version 1 (30-03-2009)
hal-00371757 , version 2 (22-09-2009)
hal-00371757 , version 3 (07-12-2009)
hal-00371757 , version 4 (23-04-2013)
  • HAL Id : hal-00371757 , version 2
Laurent Gardes, Stéphane Girard. Conditional extremes from heavy-tailed distributions: An application to the estimation of extreme rainfall return levels. 2009. ⟨hal-00371757v2⟩
520 Consultations
542 Téléchargements
