Kernel Projection Machine: a New Tool for Pattern Recognition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
This paper investigates the effect of Kernel Principal Component Analysis (KPCA) within the classification framework, essentially the regularization properties of this dimensionality reduction method. KPCA has been previously used as a pre-processing step before applying an SVM but we point out that this method is somewhat redundant from a regularization point of view and we propose a new algorithm called Kernel Projection Machine to avoid this redundancy, based on an analogy with the statistical framework of regression for a Gaussian white noise model. Preliminary experimental results show that this algorithm reaches the same performances as an SVM.
NIPSpaper672_updated.pdf (87.83 Ko) Télécharger le fichier
hal-00373801 , version 1 (07-04-2009)
  • HAL Id : hal-00373801 , version 1
Gilles Blanchard, Pascal Massart, Régis Vert, Laurent Zwald. Kernel Projection Machine: a New Tool for Pattern Recognition. nips, 2004, -, Canada. ⟨hal-00373801⟩
319 Consultations
106 Téléchargements
