On the Convergence of Eigenspaces in Kernel Principal Component Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Laurent Zwald
This paper presents a non-asymptotic statistical analysis of Kernel-PCA with a focus different from the one proposed in previous work on this topic (\cite{ShaWilCriKan02CDL}, chapter \ref{KPCA1chap}). Here instead of considering the reconstruction error of KPCA we are interested in approximation error bounds for the eigenspaces themselves. We prove an upper bound depending on the spacing between eigenvalues but not on the dimensionality of the eigenspace. As a consequence this allows to infer stability results for these estimated spaces.
Nips2005mod.pdf (107.73 Ko) Télécharger le fichier
hal-00373803 , version 1 (07-04-2009)
  • HAL Id : hal-00373803 , version 1
Laurent Zwald, Gilles Blanchard. On the Convergence of Eigenspaces in Kernel Principal Component Analysis. NIPS, 2005, Vancouver, BC, Canada. ⟨hal-00373803⟩
Collections
UNIV-PARIS-SACLAY
229 Consultations
169 Téléchargements
