Modeling Heterogeneous Real-Time Components in BIP - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Ananda Basu
  • Fonction : Auteur
  • PersonId : 857857
Marius Bozga
Joseph Sifakis
  • Fonction : Auteur
  • PersonId : 857859
We present a methodology for modeling heterogeneous real-time components. Components are obtained as the superposition of three layers : Behavior, specified as a set of transitions; Interactions between transitions of the behavior; Priorities, used to choose amongst possible interactions. A parameterized binary composition operator is used to compose components layer by layer. We present the BIP language for the description and composition of layered components as well as associated tools for executing and analyzing components on a dedicated platform. The language provides a powerful mechanism for structuring interactions involving rendezvous and broadcast. We show that synchronous and timed systems are particular classes of components. Finally, we provide examples and compare the BIP framework to existing ones for heterogeneous component-based modeling.
BIP.pdf (205.68 Ko) Télécharger le fichier
hal-00375298 , version 1 (14-04-2009)
  • HAL Id : hal-00375298 , version 1
Ananda Basu, Marius Bozga, Joseph Sifakis. Modeling Heterogeneous Real-Time Components in BIP. Fourth IEEE International Conference on Software Engineering and Formal Methods (SEFM'06), Sep 2006, Pune, India. pp.3-12. ⟨hal-00375298⟩
183 Consultations
546 Téléchargements
