Global stability of a partial differential equation with distributed delay due to cellular replication - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinear Analysis: Theory, Methods and Applications Année : 2003
In this paper, we investigate a nonlinear partial differential equation, arising from a model of cellular proliferation. This model describes the production of blood cells in the bone marrow. It is represented by a partial differential equation with a retardation of the maturation variable and a distributed temporal delay. Our aim is to prove that the behaviour of primitive cells influences the global behaviour of the population.
Global-stability.pdf (221.21 Ko) Télécharger le fichier
hal-00375926 , version 1 (16-04-2009)
Mostafa Adimy, Fabien Crauste. Global stability of a partial differential equation with distributed delay due to cellular replication. Nonlinear Analysis: Theory, Methods and Applications, 2003, 54 (8), pp.1469-1491. ⟨10.1016/S0362-546X(03)00197-4⟩. ⟨hal-00375926⟩
274 Consultations
257 Téléchargements
