Auto-Associative Models and Generalized Principal Component Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Multivariate Analysis Année : 2005
In this paper, we propose auto-associative (AA) models to generalize Principal component analysis (PCA). AA models have been introduced in data analysis from a geometrical point of view. They are based on the approximation of the observations scatter-plot by a differentiable manifold. In this paper, they are interpreted as Projection pursuit models adapted to the auto-associative case. Their theoretical properties are established and are shown to extend the PCA ones. An iterative algorithm of construction is proposed and its principle is illustrated both on simulated and real data from image analysis.
girard_iovleff.pdf (762.55 Ko) Télécharger le fichier
hal-00383139 , version 1 (23-04-2013)
Stéphane Girard, Serge Iovleff. Auto-Associative Models and Generalized Principal Component Analysis. Journal of Multivariate Analysis, 2005, 93 (1), pp.21-39. ⟨10.1016/j.jmva.2004.01.006⟩. ⟨hal-00383139⟩
173 Consultations
228 Téléchargements
