Hardy spaces of the conjugate Beltrami equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2009
We study Hardy spaces of solutions to the conjugate Beltrami equation with Lipschitz coefficient on Dini-smooth simply connected planar domains, in the range of exponents $1<\infty$. We analyse their boundary behaviour and certain density properties of their traces. We derive on the way an analog of the Fatou theorem for the Dirichlet and Neumann problems associated with the equation $\mbox{div}(\sigma\nabla u)=0$ with $L^p$-boundary data.
Hardy-2juillet09.pdf (509.92 Ko) Télécharger le fichier
hal-00401712 , version 1 (03-07-2009)
hal-00401712 , version 2 (12-03-2010)
Laurent Baratchart, Juliette Leblond, Stéphane Rigat, Emmanuel Russ. Hardy spaces of the conjugate Beltrami equation. 2009. ⟨hal-00401712v1⟩
323 Consultations
303 Téléchargements
