Feedback modulation of BCM's neurons in multi modal environment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Mathieu Lefort
Yann Boniface
  • Fonction : Auteur
  • PersonId : 835315
Bernard Girau
In Gibson's theory, an object is defined by its interactions with people, named affordances. Affordances raise from the association of the object's sensory perceptions. Bienenstock Cooper and Munro's (BCM's) cells converge to one of the input patterns with a decentralized and unsupervised learning. We want to extend this mechanism in order to develop a generic incremental modalities association paradigm. We introduce a feedback modulation of BCM's neurons to obtain a spatial auto organization. This feedback will be the reflect of the multi modal constraints.
resume_lefort_boniface_girau.pdf (399.5 Ko) Télécharger le fichier
hal-00402006 , version 1 (06-07-2009)
  • HAL Id : hal-00402006 , version 1
Mathieu Lefort, Yann Boniface, Bernard Girau. Feedback modulation of BCM's neurons in multi modal environment. Neurocomp 2009, Sep 2009, Bordeaux, France. pp.P-20. ⟨hal-00402006⟩
153 Consultations
78 Téléchargements
