EEG segmentation through time­-varying PCA - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Maxime Rio
  • Fonction : Auteur
  • PersonId : 861794
Axel Hutt
Bernard Girau
In this study, we have investigated a new method to localize ERPs components inside EEG records, in time and space. This method relies on a probabilistic model using both hidden Markov model and principal components analysis. In order to automatically select the model dimension, a Bayesian approach has been employed. Inference is realized by a variational approximation.
abstract_rio_hutt_girau.pdf (388.08 Ko) Télécharger le fichier
hal-00402047 , version 1 (06-07-2009)
  • HAL Id : hal-00402047 , version 1
Maxime Rio, Axel Hutt, Bernard Girau. EEG segmentation through time­-varying PCA. Neurocomp 2009, Sep 2009, Bordeaux, France. p. P-28. ⟨hal-00402047⟩
300 Consultations
110 Téléchargements
