Optimal timeouts for power management under renewal or hidden Markov processes for requests - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2009
This article addresses the optimal choice of the waiting period (or timeout) that a device should respect before entering sleep mode, so as to optimize a tradeoff between power consumption and user impact. The optimal timeout is inferred by appropriate statistical modeling of the times between user requests. In a test approach, these times are supposed independent, and a constant optimal timeout is inferred accordingly. In a second approach, some dependency is introduced through a hidden Markov chain, which also models specific activity states, like business hours or night periods. This model leads to a statistical framework for computing adaptive optimal timeout values. Different strategies are assessed using real datasets, on the basis of the power consumption, user impact and the frequency of wrong decisions.
rapportv2.pdf (545.41 Ko) Télécharger le fichier
hal-00412509 , version 1 (01-09-2009)
hal-00412509 , version 2 (04-06-2010)
hal-00412509 , version 3 (09-06-2010)
hal-00412509 , version 4 (12-03-2012)
  • HAL Id : hal-00412509 , version 2
Victor Ciriza, Laurent Donini, Jean-Baptiste Durand, Stéphane Girard. Optimal timeouts for power management under renewal or hidden Markov processes for requests. 2009. ⟨hal-00412509v2⟩
545 Consultations
332 Téléchargements
