A construction of the rough path above fractional Brownian motion using Volterra's representation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annals of Probability Année : 2011
David Nualart
  • Fonction : Auteur
  • PersonId : 841668
Samy Tindel
  • Fonction : Auteur
  • PersonId : 832698
This note is devoted to construct a rough path above a multidimensional fractional Brownian motion $B$ with any Hurst parameter H lesser than 1/2, by means of its representation as a Volterra Gaussian process. This approach yields some algebraic and computational simplifications with respect to a recent preprint by Unterberger, where the construction of a rough path over $B$ was first introduced.
volumes8.pdf (314.81 Ko) Télécharger le fichier
hal-00414075 , version 1 (07-09-2009)
David Nualart, Samy Tindel. A construction of the rough path above fractional Brownian motion using Volterra's representation. Annals of Probability, 2011, 39 (3), pp.1061-1096. ⟨10.1214/10-AOP578⟩. ⟨hal-00414075⟩
264 Consultations
132 Téléchargements
