MESAM: A Protégé Plug-in for the Specialization of Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Nowadays, several efforts are focused on re-using generic platforms to create new systems, in order to make the design process easier and faster. Often, the designer has his own models and resources and would like to reuse the generic system over his resources. That means, he has to integrate his models and resources in the system, and then to directly reuse the generic system. But many problems occur. One of them is that the designer needs to translate his models into the specific format that understood by the system and to use the vocabulary specific to that system. Furthermore, he also needs to translate all the instantiations of his models (i.e. the resources and their metadata). We think that this task is tedious and time-consuming and we want to avoid it. Our objective is to allow the designer to reuse his models (his vocabulary) and his models' instantiations without any change of format or vocabulary. For example, a generic Adaptive Hypermedia System (AHS) is made of a generic adaptation model relying on generic user and domain models. The designer would like to integrate his models and instances in the generic models in order to reuse the generic adaptation engine. Specific systems can be obtained by specializing the generic models. However, this specialization process is not always easy to perform. It has to be supported to make the design process easier and faster. This paper focuses on assisting designers to specialize generic models using their own models. We aim to automate this process which has been so far entirely manual. Our objectives are twofold: to create a support for defining mappings between elements in generic models and elements in the designer's personal models and to help creating consistent and relevant models integrating the generic and specific ones and taking into account the mappings between them. The proposed approach relies on OWL1, a W3C standard and SWRL2, a W3C proposal.
Protege.pdf (498.39 Ko) Télécharger le fichier
hal-00431319 , version 1 (12-02-2010)
  • HAL Id : hal-00431319 , version 1
Nadjet Zemirline, Yolaine Bourda, Chantal Reynaud, Fabrice Popineau. MESAM: A Protégé Plug-in for the Specialization of Models. 11th International Protégé Conference, Jun 2009, Amsterdam, Netherlands. 3 p. ⟨hal-00431319⟩
253 Consultations
155 Téléchargements
