A comparison of statistical learning approaches for engine torque estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Control Engineering Practice Année : 2008
Engine torque estimation has important applications in the automotive industry: for example, automatically setting gears, optimizing engine perfor- mance, reducing emissions and designing drivelines. A methodology is described for the on-line calculation of torque values from the gear, the accelerator pedal position and the engine rotational speed. It is based on the availability of input-torque experimental signals that are pre- processed (resampled, filtered and segmented) and then learned by a statistical machine-learning method. Four methods, spanning the main learning principles, are reviewed in a uni- fied framework and compared using the torque estimation problem: linear least squares, linear and non-linear neural networks and support vector machines. It is found that a non-linear model structure is necessary for accurate torque estimation. The most efficient torque model built is a non-linear neural net- work that achieves about 2% test normalized mean square error in nominal conditions.
Informatique
engine.pdf (2.28 Mo) Télécharger le fichier
hal-00439467 , version 1 (07-12-2009)
A. Rakotomamonjy, Rodolphe Le Riche, David Gualandris, Zaid Harchaoui. A comparison of statistical learning approaches for engine torque estimation. Control Engineering Practice, 2008, 16, pp.43-55. ⟨10.1016/j.conengprac.2007.03.009⟩. ⟨hal-00439467⟩
173 Consultations
628 Téléchargements
