Intrinsic Dimension Estimation by Maximum Likelihood in Probabilistic PCA - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2010
A central issue in dimension reduction is choosing a sensible number of dimensions to be retained. This work demonstrates the asymptotic consistency of the maximum likelihood criterion for determining the intrinsic dimension of a dataset in a isotropic version of Probabilistic Principal Component Analysis (PPCA). Numerical experiments on simulated and real datasets show that the maximum likelihood criterion can actually be used in practice and outperforms existing intrinsic dimension selection criteria in various situations. This paper exhibits as well the limits of the maximum likelihood criterion and recommends in specific situations the use of the AIC criterion.
preprint_PPCAds.pdf (162.74 Ko) Télécharger le fichier
hal-00440372 , version 1 (10-12-2009)
hal-00440372 , version 2 (25-01-2010)
hal-00440372 , version 3 (11-07-2011)
  • HAL Id : hal-00440372 , version 2
Charles Bouveyron, Gilles Celeux, Stéphane Girard. Intrinsic Dimension Estimation by Maximum Likelihood in Probabilistic PCA. 2010. ⟨hal-00440372v2⟩
2967 Consultations
1083 Téléchargements
