Additive Kernels for Gaussian Process Modeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Annales de la Facultée de Sciences de Toulouse Année : 2010
Gaussian Process (GP) models are often used as mathematical approximations of computationally expensive experiments. Provided that its kernel is suitably chosen and that enough data is available to obtain a reasonable fit of the simulator, a GP model can beneficially be used for tasks such as prediction, optimization, or Monte-Carlo-based quantification of uncertainty. However, the former conditions become unrealistic when using classical GPs as the dimension of input increases. One popular alternative is then to turn to Generalized Additive Models (GAMs), relying on the assumption that the simulator's response can approximately be decomposed as a sum of univariate functions. If such an approach has been successfully applied in approximation, it is nevertheless not completely compatible with the GP framework and its versatile applications. The ambition of the present work is to give an insight into the use of GPs for additive models by integrating additivity within the kernel, and proposing a parsimonious numerical method for data-driven parameter estimation. The first part of this article deals with the kernels naturally associated to additive processes and the properties of the GP models based on such kernels. The second part is dedicated to a numerical procedure based on relaxation for additive kernel parameter estimation. Finally, the efficiency of the proposed method is illustrated and compared to other approaches on Sobol's g-function.
CSDA.pdf (261.14 Ko) Télécharger le fichier
hal-00446520 , version 1 (19-01-2010)
hal-00446520 , version 2 (21-03-2011)
Nicolas Durrande, David Ginsbourger, Olivier Roustant. Additive Kernels for Gaussian Process Modeling. 2010, pp.17. ⟨hal-00446520v2⟩
504 Consultations
757 Téléchargements
