Multigoal output regulation via supervisory control: Application to stabilization of a unicycle - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Denis Efimov
Elena Panteley
Antonio Loria
We consider the problem of robust output regulation for nonlinear systems in the following sense: given a system with input disturbances, we are interested in steering one output to zero while tolerating an steady-state error on the second output. In other words, we are interested in inputoutput (asymptotic) stability for one output and practical (asymptotic) stability for the second. Upon the assumption that we dispose of two controllers each of which achieves separately a control objective (for either output) we propose a switching rule to commute between the two controllers appropriately i.e., conserving the input-output stability, to some extent. The problem studied is reminiscent of different concrete situations such as simultaneaous synchronization and tracking control of mechanical systems; in this article we revisit the problem of stabilizing a unicycle (regulation of the first output) towards a point while ensuring obstacle-collision avoidance (practical stabilization of the second output).
Automatique
IEEEXplore_3.pdf (1.03 Mo) Télécharger le fichier
hal-00447658 , version 1 (15-01-2010)
  • HAL Id : hal-00447658 , version 1
Denis Efimov, Elena Panteley, Antonio Loria. Multigoal output regulation via supervisory control: Application to stabilization of a unicycle. American Control Conference, Jun 2009, St Louis Missouri, United States. pp.4340-4345. ⟨hal-00447658⟩
129 Consultations
115 Téléchargements
