Gaussian mixture models for the classification of high-dimensional vibrational spectroscopy data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2010
In this work, a family of generative Gaussian models designed for the supervised classification of high-dimensional data is presented as well as the associated classification method called High Dimensional Discriminant Analysis (HDDA). The advantages of these Gaussian models are: i) the representation of the input density model is smooth; ii) the data of each class are modeled in a specific subspace of low dimensionality; iii) each class may have its own covariance structure; iv) regularization is coupled to the classification criterion to avoid data over-fitting. To illustrate the abilities of the method, HDDA is applied on complex high-dimensional multi-class classification problems in mid-infrared and near infrared spectroscopy and compared to state-of-the-art methods.
paper_Jacques_et_al.pdf (933.95 Ko) Télécharger le fichier
hal-00459947 , version 1 (25-02-2010)
hal-00459947 , version 2 (30-06-2010)
  • HAL Id : hal-00459947 , version 1
Julien Jacques, Charles Bouveyron, Stéphane Girard, Olivier Devos, Ludovic Duponchel, et al.. Gaussian mixture models for the classification of high-dimensional vibrational spectroscopy data. 2010. ⟨hal-00459947v1⟩
503 Consultations
1125 Téléchargements
