A Nekhoroshev-type theorem for the nonlinear Schrödinger equation on the torus. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Analysis & PDE Année : 2013
We prove a Nekhoroshev type theorem for the nonlinear Schrödinger equation $$ iu_t=-\Delta u+V\star u+\partial_{\bar u}g(u,\bar u)\ , \quad x\in \T^d, $$ where $V$ is a typical smooth potential and $g$ is analytic in both variables. More precisely we prove that if the initial datum is analytic in a strip of width $\rho>0$ with a bound on this strip equals to $\eps$ then, if $\eps$ is small enough, the solution of the nonlinear Schrödinger equation above remains analytic in a strip of width $\rho/2$ and bounded on this strip by $C\eps$ during very long time of order $ \eps^{-\alpha|\ln \eps|^\beta}$ for some constants $C> 0$, $\alpha>0$ and $\beta<1$.
NekoPDE5.pdf (199.85 Ko) Télécharger le fichier
hal-00466803 , version 1 (24-03-2010)
Erwan Faou, Benoît Grébert. A Nekhoroshev-type theorem for the nonlinear Schrödinger equation on the torus.. Analysis & PDE, 2013, 6 (6), pp.1243-4262. ⟨10.2140/apde.2013.6.1243⟩. ⟨hal-00466803⟩
258 Consultations
240 Téléchargements
