MONOTONE ADAPTIVE SET OBSERVERS FOR NONLINEAR CONTINUOUS-TIME SYSTEMS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The paper deals with joint state and parameter estimation for nonlinear continuous-time systems. Based on a guaranteed LPV approximation, the problem of set observers design is recasted into more general adaptive observers design problem in order to avoid the exponential complexity obstruction usually met in the set-membership nonlinear estimation. The efficacy of the proposed set adaptive observer is demonstrated on a bioreactor example.
Mots clés
Automatique
Fichier non déposé
hal-00470119 , version 1 (03-04-2010)
  • HAL Id : hal-00470119 , version 1
Denis Efimov, Tarek Raissi, Ali Zolghadri. MONOTONE ADAPTIVE SET OBSERVERS FOR NONLINEAR CONTINUOUS-TIME SYSTEMS. NOLCOS 2010, Sep 2010, Bologne, Italy. ⟨hal-00470119⟩
82 Consultations
0 Téléchargements
