Adaptive Set Observers Design For Fault Detection And Diagnosis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper deals with fault detection problem for nonlinear continuous-time systems transformed to a LPV form. Adaptive set observers techniques are applied for joint state and parameter estimation in order to avoid the exponential complexity obstruction usually met in set-membership nonlinear estimation. The obtained estimates on the sets of admissible values for the parameters and the state are used for interval residuals generation. The efficacy of the proposed approach is demonstrated on a three-tank-system benchmark.
Automatique
Fichier non déposé
hal-00480928 , version 1 (05-05-2010)
  • HAL Id : hal-00480928 , version 1
Denis Efimov, Tarek Raissi, Ali Zolghadri. Adaptive Set Observers Design For Fault Detection And Diagnosis. 18th Mediterranean Conference on Control and Automation, Jun 2010, Marrakech, Morocco. ⟨hal-00480928⟩
72 Consultations
0 Téléchargements
