Collision-free walk planning for humanoid robots using numerical optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2010
This paper addresses the problem of walk planning for a humanoid robot on a flat ground cluttered by obstacles. The algorithm we propose works in two steps. In a first step, a collision-free path for the bounding box of the robot moving in the horizontal plane is planned using classical path planning methods. In a second step, a spline is fit on the path and optimized using numerical optimization tools. The optimization criterion is time, constraints are defined by positive distance to obstacles and bounded velocities of the feet. The method has been tested on a real humanoid robot HRP-2.
iros.10.pdf (1.32 Mo) Télécharger le fichier
hal-00486997 , version 1 (07-09-2010)
  • HAL Id : hal-00486997 , version 1
Thomas Moulard, Florent Lamiraux, Pierre-Brice Wieber. Collision-free walk planning for humanoid robots using numerical optimization. 2010. ⟨hal-00486997⟩
438 Consultations
255 Téléchargements
