InterCell: a Software Suite for Rapid Prototyping and Parallel Execution of Fine Grained Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
InterCell is an open, operational software suite for implementation, code generation and interactive simulation of fine grained parallel computational models. This article describes the software architecture, some use cases from physics and cortical networks as well as first performance measurements.
Supelec614.pdf (613.84 Ko) Télécharger le fichier
hal-00491969 , version 1 (14-06-2010)
  • HAL Id : hal-00491969 , version 1
Jens Gustedt, Stéphane Vialle, Hervé Frezza-Buet, d'Havh Boumba Sitou, Nicolas Fressengeas. InterCell: a Software Suite for Rapid Prototyping and Parallel Execution of Fine Grained Applications. PARA 2010 : State of the Art in Scientific and Parallel Computing, Jun 2010, Reykjavick, Iceland. 4 p. ⟨hal-00491969⟩
204 Consultations
351 Téléchargements
