Impact of asynchronism on GPU accelerated parallel iterative computations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We study the impact of asynchronism on parallel iterative algorithms in the particular context of local clusters of workstations including GPUs. The application test is a classical PDE problem of advection-diffusion-reaction in 3D. We propose an asynchronous version of a previously developed PDE solver using GPUs for the inner computations. The algorithm is tested with two kinds of clusters, a homogeneous one and a heterogeneous one.
Supelec620.pdf (102.37 Ko) Télécharger le fichier
hal-00491976 , version 1 (14-06-2010)
  • HAL Id : hal-00491976 , version 1
Sylvain Contassot-Vivier, Thomas Jost, Stéphane Vialle. Impact of asynchronism on GPU accelerated parallel iterative computations. PARA 2010 : State of the Art in Scientific and Parallel Computing, Jun 2010, Reykjavik, Iceland. 4 p. ⟨hal-00491976⟩
167 Consultations
159 Téléchargements
