Multi-Target Vectorization With MTPS C++ Generic Library - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Wilfried Kirschenmann
EDF
Laurent Plagne
  • Fonction : Auteur
EDF
This article introduces MTPS, a C++ template library dedicated at vectorizing algorithms for different target architectures. Algorithms written with MTPS benefit from optimized memory access patterns and show performances close to hardware limits, both on multicore CPU and on GPU.
Supelec621.pdf (119.15 Ko) Télécharger le fichier
hal-00491980 , version 1 (14-06-2010)
  • HAL Id : hal-00491980 , version 1
Wilfried Kirschenmann, Laurent Plagne, Stéphane Vialle. Multi-Target Vectorization With MTPS C++ Generic Library. PARA 2010 : State of the Art in Scientific and Parallel Computing, Jun 2010, Reykjavik, Iceland. 4 p. ⟨hal-00491980⟩
200 Consultations
230 Téléchargements
