Models of stochastic gene expression and Weyl algebra - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Lecture Notes in Computer Science Année : 2010
This paper presents a symbolic algorithm for computing the ODE systems which describe the evolution of the moments associated to a chemical reaction system, considered from a stochastic point of view. The algorithm, which is formulated in the Weyl algebra, seems more efficient than the corresponding method, based on partial derivatives. In particular, an efficient method for handling conservation laws is presented. The output of the algorithm can be used for a further investigation of the system behaviour, by numerical methods. Relevant examples are carried out.
vidaleEtAl2010.pdf (317.7 Ko) Télécharger le fichier
hal-00492438 , version 1 (11-12-2010)
hal-00492438 , version 2 (25-06-2011)
  • HAL Id : hal-00492438 , version 1
Samuel Alexandre Vidal, Michel Petitot, François Boulier, François Lemaire, Celine Kuttler. Models of stochastic gene expression and Weyl algebra. Lecture Notes in Computer Science, 2010, Lecture Notes in Computer Science. ⟨hal-00492438v1⟩
Collections
LIFL BIOCOMPUTING
289 Consultations
475 Téléchargements
