Parallel arithmetic encryption for high-bandwidth communications on multicore/GPGPU platforms. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work we study the feasibility of high-bandwidth, secure communications on generic machines equipped with the latest CPUs and General-Purpose Graphical Processing Units (GPGPU). We first analyze the suitability of current Nehalem CPU architectures. We show in particular that high performance CPUs are not sufficient by themselves to reach our performance objectives, and that encryption is the main bottleneck. Therefore we also consider the use of GPGPU, and more particularly we measure the bandwidth of the AES ciphering on CUDA. These tests lead us to the conclusion that finding an appropriate solution is extremely difficult.
paper.pdf (220.2 Ko) Télécharger le fichier
hal-00493044 , version 1 (23-06-2010)
Ludovic Jacquin, Vincent Roca, Jean-Louis Roch, Mohamed Alali. Parallel arithmetic encryption for high-bandwidth communications on multicore/GPGPU platforms.. PASCO '10 - 4th International Workshop on Parallel and Symbolic Computation, Jul 2010, Grenoble, France. pp.Pages 73-79, ⟨10.1145/1837210.1837223⟩. ⟨hal-00493044⟩
310 Consultations
405 Téléchargements
