Basic Concepts in Augmented Reality Audio - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jacques Lemordant
  • Fonction : Auteur
  • PersonId : 844754
The basic difference between real and virtual sound environments is that virtual sounds are originating from another environment or are artificially created, whereas the real sounds are the natural existing sounds in the user's own environment. Augmented Reality Audio combines these aspects in a way where real and virtual sound scenes are mixed so that virtual sounds are perceived as an extension or a complement to the natural ones.
basic_concepts_in_ar_audio.pdf (93.72 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-00494276 , version 1 (22-06-2010)
  • HAL Id : hal-00494276 , version 1
Jacques Lemordant. Basic Concepts in Augmented Reality Audio. W3C Workshop: Augmented Reality on the Web, Jun 2010, Barcelona, Spain. pp.4. ⟨hal-00494276⟩
309 Consultations
247 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
