Comparison of Capture Point estimation with human foot placement: Applicability and Limitations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
For bipeds like humans, taking a step to recover its balance is fundamental. The question that arises is the location where the biped should step. Pratt et al. developed an algorithm to estimate the so-called Capture Point, a point on ground where a robot can step in order to bring itself to a complete stop. The objective of the current work is to test the applicability of the algorithm for the prediction of step location in humans under perturbed state.
Resume_JNRH_10_Aftab_Z.pdf (87.77 Ko) Télécharger le fichier
JNRH_10.pdf (1.96 Mo) Télécharger le fichier
Format : Autre
hal-00494610 , version 1 (23-06-2010)
  • HAL Id : hal-00494610 , version 1
Zohaib Aftab, Thomas Robert, Pierre-Brice Wieber. Comparison of Capture Point estimation with human foot placement: Applicability and Limitations. 5èmes Journées Nationales de la Robotique Humanoïde, Jun 2010, Poitiers, France. ⟨hal-00494610⟩
617 Consultations
417 Téléchargements
