Interactive Searching and Visualization of Patterns in Attributed Graphs. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Searching for patterns in graphs and visualizing the search results is an active area of research with numerous applications. With the continual growth of database size, querying these databases often results in multiple solutions. Text-based systems present search results as a list, and going over all solutions can be tedious. In this paper, we present an interactive visualization system that helps users find patterns in graphs and visualizes the search results. The user draws a source pattern and labels it with attributes. Based on these attributes and connectivity constraints, simplified subgraphs are generated, containing all the possible solutions. The system is quite generic and capable of searching patterns and approximate solutions in a variety of data sets.
graphPatternMatch.pdf (1.06 Mo) Télécharger le fichier
hal-00499430 , version 1 (09-07-2010)
  • HAL Id : hal-00499430 , version 1
Pierre-Yves Koenig, Faraz Zaidi, D. Archambault. Interactive Searching and Visualization of Patterns in Attributed Graphs.. Proceedings of Graphics Interface, May 2010, Canada. pp.113--120. ⟨hal-00499430⟩
Collections
CNRS INRIA INRIA2
138 Consultations
218 Téléchargements
