On the influence of the geometry on skin effect in electromagnetism - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2010
We consider the equations of electromagnetism set on a domain made of a dielectric and a conductor subdomain in a regime where the conductivity is large. Assuming smoothness for the dielectric--conductor interface, relying on recent works we prove that the solution of the Maxwell equations admits a multiscale asymptotic expansion with profile terms rapidly decaying inside the conductor. This skin effect is measured by introducing a skin depth function that turns out to depend on the mean curvature of the boundary of the conductor. We then confirm these asymptotic results by numerical experiments in various axisymmetric configurations. We also investigate numerically the case of a nonsmooth interface, namely a cylindrical conductor.
CaDaFaPe10.pdf (1.29 Mo) Télécharger le fichier
hal-00503170 , version 1 (16-07-2010)
hal-00503170 , version 2 (01-11-2010)
  • HAL Id : hal-00503170 , version 1
Gabriel Caloz, Monique Dauge, Erwan Faou, Victor Péron. On the influence of the geometry on skin effect in electromagnetism. 2010. ⟨hal-00503170v1⟩
1146 Consultations
773 Téléchargements
