Bio-inspired visual sequences classification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mauricio Cerda
  • Fonction : Auteur
  • PersonId : 843075
Bernard Girau
The capacity to perceive and interpret highly complex visual patterns such as body movements and face gestures, is remarkably efficient in humans and many other species. Among others tasks, the classification of visual sequences without context is a key problem to understand both the coding and the retrieval of spatiotemporal patterns in the human brain. In this work we present a model able to discriminate visual sequences. This model is based on asymmetric neural fields. We apply it to the classification of synthetic sequences. Our model takes into account several properties exhibited by experimental psychophysics and physiology. The presented model shows that sparse spatial coding of spatiotemporal sequences could be sufficient to explain some of these properties, such as classification with partial sequence information and tolerance to time-warping. We are also able to code a temporal sequence with a single population of units, without the need of explicit “snapshots” at each time instant.
bics10.pdf (197.18 Ko) Télécharger le fichier
hal-00504090 , version 1 (19-07-2010)
  • HAL Id : hal-00504090 , version 1
Mauricio Cerda, Bernard Girau. Bio-inspired visual sequences classification. Brain Inspired Cognitive Systems 2010 - BICS 2010, Jul 2010, Madrid, Spain. pp. 20. ⟨hal-00504090⟩
173 Consultations
492 Téléchargements
