Structured sparsity-inducing norms through submodular functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2010
Sparse methods for supervised learning aim at finding good linear predictors from as few variables as possible, i.e., with small cardinality of their supports. This combinatorial selection problem is often turned into a convex optimization problem by replacing the cardinality function by its convex envelope (tightest convex lower bound), in this case the L1-norm. In this paper, we investigate more general set-functions than the cardinality, that may incorporate prior knowledge or structural constraints which are common in many applications: namely, we show that for nonincreasing submodular set-functions, the corresponding convex envelope can be obtained from its Lovasz extension, a common tool in submodular analysis. This defines a family of polyhedral norms, for which we provide generic algorithmic tools (subgradients and proximal operators) and theoretical results (conditions for support recovery or high-dimensional inference). By selecting specific submodular functions, we can give a new interpretation to known norms, such as those based on rank-statistics or grouped norms with potentially overlapping groups; we also define new norms, in particular ones that can be used as non-factorial priors for supervised learning.
submodular_hal.pdf (581.61 Ko) Télécharger le fichier
hal-00511310 , version 1 (24-08-2010)
hal-00511310 , version 2 (22-09-2010)
hal-00511310 , version 3 (12-11-2010)
Francis Bach. Structured sparsity-inducing norms through submodular functions. 2010. ⟨hal-00511310v1⟩
294 Consultations
170 Téléchargements
