Numerical treatment of rounded and sharp corners in the modeling of 2D electrostatic fields - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Microwaves, Optoelectronics and Electromagnetic Applications Année : 2010
Laurent Krähenbühl
Connectez-vous pour contacter l'auteur
François Buret
Ronan Perrussel
Damien Voyer
  • Fonction : Auteur
  • PersonId : 841634
Victor Péron
This work deals with numerical techniques to compute electrostatic fields in devices with rounded corners in 2D situations. The approach leads to the solution of two problems: one on the device where rounded corners are replaced by sharp corners and the other on an unbounded domain representing the shape of the rounded corner after an appropriate rescaling. Both problems are solved using different techniques and numerical results are provided to assess the efficiency and the accuracy of the techniques.
Krahenbuhl_JMOE2011_rounded_corner.pdf (692.99 Ko) Télécharger le fichier
hal-00515107 , version 1 (04-09-2010)
hal-00515107 , version 2 (06-09-2010)
hal-00515107 , version 3 (07-09-2010)
  • HAL Id : hal-00515107 , version 2
Laurent Krähenbühl, François Buret, Ronan Perrussel, Damien Voyer, Patrick Dular, et al.. Numerical treatment of rounded and sharp corners in the modeling of 2D electrostatic fields. Journal of Microwaves, Optoelectronics and Electromagnetic Applications, 2010. ⟨hal-00515107v2⟩
Collections
AMPERE
1574 Consultations
521 Téléchargements
