Improved stability analysis of networked control systems under asynchronous sampling and input delay - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Wenjuan Jiang
  • Fonction : Auteur
  • PersonId : 847798
Alexandre Seuret
This article presents a novel approach to assess the stability of linear systems with delayed and sampled-data inputs. It proposes an extension of existing results on the stability of sampled-data systems to the case where a delay is introduced in the control loop. The method is based on a continuous-time modeling of the systems together with the discrete-time Lyapunov theorem, which provides easy tractable sufficient conditions for asymptotic stability. Those conditions cope the problem of stability under asynchronous samplings and time-varying delays. The period and delay-dependent conditions are expressed using computable linear matrix inequalities. Several examples show the efficiency of the stability criteria.
0073.pdf (223.26 Ko) Télécharger le fichier
hal-00515425 , version 1 (06-09-2010)
Wenjuan Jiang, Alexandre Seuret. Improved stability analysis of networked control systems under asynchronous sampling and input delay. NecSys 2010 - 2nd IFAC Workshop on Distributed Estimation and Control in Networked Systems, Sep 2010, Annecy, France. pp.073, ⟨10.3182/20100913-2-FR-4014.00073⟩. ⟨hal-00515425⟩
438 Consultations
279 Téléchargements
