Sensorless Control of a Stepper Motor Based on Higher Order Sliding Modes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A robust control for a stepper motor with no position nor velocity sensors and only needing current and voltage measurements is designed. Second order sliding mode based observers are realized to estimate both rotor angular position and velocity. Moreover, a robust control law, which is also based on second order sliding modes and which uses the estimates of the observer, is designed. The stability of the observer based control loop is discussed. The results obtained in simulations indicate the usefulness and the robustness of the method.
Automatique
NOLCOS2010_-_Fiter_Floquet_and_Rudolph.pdf (288.63 Ko) Télécharger le fichier
hal-00517870 , version 1 (15-09-2010)
  • HAL Id : hal-00517870 , version 1
Christophe Fiter, Thierry Floquet, Joachim Rudolph. Sensorless Control of a Stepper Motor Based on Higher Order Sliding Modes. 8th IFAC Symposium on Nonlinear Control Systems (NOLCOS 2010), Sep 2010, Bologna, Italy. ⟨hal-00517870⟩
376 Consultations
1047 Téléchargements
