From Databases to Graph Visualization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The first step of any information visualization system is to enable end user to import their dataset into the system. However, non expert user are faced to the difficult task of choosing how their data should/could be transform to be used in these Infovis systems. In that paper we address the case where end users want to use dataset in tabular format. We propose a novel method for automatic graph generation from these datasets. That method consists in first building taxonomy of dimensions. Then, that taxonomy is used to provide to user a system that enables to interactively navigate into the set of possible data transformation.
FromDataBaseToVisu_Formated_GILBERT_AUBER.pdf (410.57 Ko) Télécharger le fichier
hal-00520906 , version 1 (24-09-2010)
  • HAL Id : hal-00520906 , version 1
Frédéric Gilbert, David Auber. From Databases to Graph Visualization. 2010 14th International Conference Information Visualisation, Jul 2010, London, United Kingdom. pp.128. ⟨hal-00520906⟩
380 Consultations
208 Téléchargements
