Mining Complex Hydrobiological Data with Galois Lattices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Computing and Information Sciences (IJCIS) Année : 2010
We used Galois lattices for mining hydrobiological data about macrophytes, i.e. macroscopic plants living in water bodies. These plants are characterized by several biological traits, that are divided into several modalities. Our aim was to cluster the plants according to their common traits and modalities and to find out the relations between the traits. Galois lattices are efficient methods for such an aim, but apply to binary data. In this article, we detail a few of the approaches we used to turn complex hydrobiological data into binary data and compare the first results obtained thanks to Galois lattices.
bertaux-ijcis.pdf (1.05 Mo) Télécharger le fichier
hal-00531756 , version 1 (03-11-2010)
  • HAL Id : hal-00531756 , version 1
Aurélie Bertaux, Florence Le Ber, Agnès Braud, Michèle Trémolières. Mining Complex Hydrobiological Data with Galois Lattices. International Journal of Computing and Information Sciences (IJCIS), 2010, 7 (2), pp.63--77. ⟨hal-00531756⟩
219 Consultations
118 Téléchargements
