Adaptive Control Design for a Boost Inverter - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Control Engineering Practice Année : 2010
In this paper, a novel control strategy for a nonlinear boost inverter is proposed. The idea is based on generating an autonomous oscillator that does not need an external reference signal. This aim is achieved by using energy shaping methodology with a suitable Hamiltonian function which defines the desired system behavior. A phase controller is added to the control law in order to achieve 180◦-synchronization between both parts of the circuit as well as synchronize the voltage output with a pre-specified signal, e.g. synchronization with the electrical grid. An adaptive control is designed for dealing with the common problem of unknown load. In order to analyze the stability of the full system, singular perturbation approach is used. The resulting control is tested by means of simulations.
JCEP.pdf (858.73 Ko) Télécharger le fichier
hal-00531760 , version 1 (04-11-2010)
Carolina Albea-Sanchez, Francisco Gordillo, Carlos Canudas de Wit. Adaptive Control Design for a Boost Inverter. Control Engineering Practice, 2010, 19 (1), pp.32-44. ⟨10.1016/j.conengprac.2010.08.007⟩. ⟨hal-00531760⟩
333 Consultations
651 Téléchargements
