Design and Experimentation of a Large Scale Distributed Stochastic Control Algorithm Applied to Energy Management Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2010
Xavier Warin
  • Fonction : Auteur
  • PersonId : 858650
EDF
The Stochastic Dynamic Programming method often used to solve some stochastic optimization problems is only usable in low dimension, being plagued by the curse of dimensionality. In this article, we explain how to postpone this limit by using High Performance Computing: parallel and distributed algorithms design, optimized implementations and usage of large scale distributed architectures (PC clusters and Blue Gene/P).
Fichier non déposé
hal-00537341 , version 1 (18-11-2010)
  • HAL Id : hal-00537341 , version 1
Xavier Warin, Stéphane Vialle. Design and Experimentation of a Large Scale Distributed Stochastic Control Algorithm Applied to Energy Management Problems. Chris Myers. Stochastic Control, Sciyo, pp.103-124, 2010. ⟨hal-00537341⟩
168 Consultations
0 Téléchargements
