Some inverse problems around the tokamak Tore Supra - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2010
We consider two inverse problems related to the tokamak Tore Supra. The first one deals with the Cauchy issue of recovering in a two dimensional annular domain boundary magnetic values on the inner boundary, namely the limiter, from available overdetermined data on the outer boundary, for solutions to the Grad-Shafranov equation. Using tools from complex analysis and properties of genereralized Hardy spaces, we establish stability and existence properties. Secondly the inverse problem of recovering the shape of the plasma is addressed thank tools of shape optimization. Here too, results about existence and optimality are provided. They give rise to a fast algorithm of identification which is applied to several numerical simulations computing good results either for the classical harmonic case or for the data coming from Tore Supra.
tokaHal_FMP.pdf (783.25 Ko) Télécharger le fichier
hal-00537648 , version 1 (18-11-2010)
hal-00537648 , version 2 (21-04-2011)
hal-00537648 , version 3 (06-04-2012)
  • HAL Id : hal-00537648 , version 1
Yannick Fischer, Benjamin Marteau, Yannick Privat. Some inverse problems around the tokamak Tore Supra. 2010. ⟨hal-00537648v1⟩
647 Consultations
258 Téléchargements
