Distributed Estimation over Unknown Fading Channels - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Alain Kibangou
In this paper, we consider the data detection problem involved in distributed estimation over unknown non-orthogonal fading channel. In general, when studying the distributed estimation problem, the impairments induced by communication channels are restricted to additive noise, quantization or packet loss. In addition, communication protocols are often of TDMA or FDMA type. Herein, by modulating the local data with doubly spread waveforms, we show that although each node receives a mixture of data transmitted by its neighbors, these data exhibit a trilinear structure, which can be used for separating the neighbors contributions. We state identifiability conditions and study the embedding of the data detection steps in a distributed estimation problem.
Kibangou_necsys_10.pdf (240.17 Ko) Télécharger le fichier
hal-00540821 , version 1 (29-11-2010)
Alain Kibangou. Distributed Estimation over Unknown Fading Channels. NecSys 2010 - 2nd IFAC Workshop on Distributed Estimation and Control in Networked Systems, Sep 2010, Annecy, France. ⟨10.3182/20100913-2-FR-4014.00077⟩. ⟨hal-00540821⟩
291 Consultations
178 Téléchargements
