Novel genes differentially expressed between posterior and median silk gland identified by SAGE-aided transcriptome analysis. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Insect Biochemistry and Molecular Biology Année : 2010
Serial analysis of gene expression (SAGE) profiles, from posterior and median cells of the silk gland of Bombyx mori, were analyzed and compared, so as to identify their respective distinguishing functions. The annotation of the SAGE libraries was performed with a B. mori reference tag collection, which was extracted from a novel set of Bombyx ESTs, sequenced from the 3' side. Most of the tags appeared at similar relative concentration within the two libraries, and corresponded with region-specific and highly abundant silk proteins. Strikingly, in addition to tags from silk protein mRNAs, 19 abundant tags were found (≥0.1%), in the median cell library, which were absent in the posterior cell tag collection. With the exception of tags from SP1 mRNA, no PSG specific tags were found in this subset class. The analysis of some of the MSG-specific transcripts, suggested that middle silk gland cells have diversified functions, in addition to their well characterized role in silk sericins synthesis and secretion.
hal-00542448 , version 1 (02-12-2010)
Corinne Royer, Jérôme Briolay, Annie Garel, Patrick Brouilly, Shun-Ichi Sasanuma, et al.. Novel genes differentially expressed between posterior and median silk gland identified by SAGE-aided transcriptome analysis.. Insect Biochemistry and Molecular Biology, 2010, 41 (2), epub ahead of print. ⟨10.1016/j.ibmb.2010.11.003⟩. ⟨hal-00542448⟩
313 Consultations
0 Téléchargements
