Stability and Hopf bifurcation for a cell population model with state-dependent delay - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Applied Mathematics Année : 2010
We propose a mathematical model describing the dynamics of a hematopoietic stem cell population. The method of characteristics reduces the age-structured model to a system of differential equations with a state-dependent delay. A detailed stability analysis is performed. A sufficient condition for the global asymptotic stability of the trivial steady state is obtained using a Lyapunov-Razumikhin function. A unique positive steady state is shown to appear through a transcritical bifurcation of the trivial steady state. The analysis of the positive steady state behavior, through the study of a first order exponential polynomial characteristic equation, concludes the existence of a Hopf bifurcation and gives criteria for stability switches. A numerical analysis confirms the results and stresses the role of each parameter involved in the system on the stability of the positive steady state.
AdimyCrausteHbidQesmiSIAP2010.pdf (364.27 Ko) Télécharger le fichier
hal-00542655 , version 1 (01-08-2019)
Mostafa Adimy, Fabien Crauste, Hassan Hbid, Redouane Qesmi. Stability and Hopf bifurcation for a cell population model with state-dependent delay. SIAM Journal on Applied Mathematics, 2010, 70 (5), pp.1611-1633. ⟨10.1137/080742713⟩. ⟨hal-00542655⟩
262 Consultations
160 Téléchargements
