Shaping Level Sets with Submodular Functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider a class of sparsity-inducing regularization terms based on submodular functions. While previous work has focused on non-decreasing functions, we explore symmetric submodular functions and their \lova extensions. We show that the Lovasz extension may be seen as the convex envelope of a function that depends on level sets (i.e., the set of indices whose corresponding components of the underlying predictor are greater than a given constant): this leads to a class of convex structured regularization terms that impose prior knowledge on the level sets, and not only on the supports of the underlying predictors. We provide a unified set of optimization algorithms, such as proximal operators, and theoretical guarantees (allowed level sets and recovery conditions). By selecting specific submodular functions, we give a new interpretation to known norms, such as the total variation; we also define new norms, in particular ones that are based on order statistics with application to clustering and outlier detection, and on noisy cuts in graphs with application to change point detection in the presence of outliers.
symm_sub_hal_v2.pdf (336.91 Ko) Télécharger le fichier
hal-00542949 , version 1 (06-12-2010)
hal-00542949 , version 2 (10-06-2011)
Francis Bach. Shaping Level Sets with Submodular Functions. Neural Information Processing Systems (NIPS), 2011, Spain. ⟨hal-00542949v2⟩
159 Consultations
343 Téléchargements
