A stable decomposition algorithm for dynamical social network analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2010
Dynamic networks raise new knowledge discovery challenges. To handle efficiently this kind of data, an analysis method has to both decompose the network (modelled by a graph) into similar set of nodes and let the user detect structural changes in the graph. In this article we present a graph decomposition algorithm generating overlapping clusters. The complexity of this algorithmis O(|E|·deg_max^2+|V| · log(|V|))). This algorithm is particularly efficient due to its ability to detect major modifications along dynamic processes such as time related ones.
author.DMKM.pdf (940.97 Ko) Télécharger le fichier
hal-00543175 , version 1 (06-12-2010)
Romain Bourqui, Paolo Simonetto, Fabien Jourdan. A stable decomposition algorithm for dynamical social network analysis. Fabrice Guillet; Gilbert Ritschard; Djamel Abdelkader Zighed and Henri Briand. Advances in Knowledge Discovery and Management, Springer, pp.167-178, 2010, Studies in Computational Intelligence, ⟨10.1007/978-3-642-00580-0_10⟩. ⟨hal-00543175⟩
155 Consultations
190 Téléchargements
