A mathematical model for the interpretation of nuclear bomb test derived 14C incorporation in biological systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nuclear Instruments and Methods in Physics Research Section B: Beam Interactions with Materials and Atoms Année : 2010
Human tissues continually replace dying cells with newborn cells. However, the rate of renewal varies by orders of magnitudes between blood cells, which are renewed every day and neurons, for which renewal is non-existent or limited to specific regions of the brain. Between those extreme are many tissues that turnover on a time scale of years, although no direct measurements have been done. We present here a mathematical method to estimate cell turnover in slowly renewing biological systems. Age distribution of DNA can be estimated from the integration of radiocarbon derived from nuclear bomb-testing during the cold war (1955–1963). For slowly renewing tissues, this method provides a better estimate of the average age of the tissue than direct estimates from the bomb-curve. Moreover, death, birth and turnover rates can be estimated. We highlight this method with data from human fat cells.
bernardNIMB.pdf (137.88 Ko) Télécharger le fichier
hal-00544517 , version 1 (08-12-2010)
hal-00544517 , version 2 (10-12-2011)
Samuel Bernard, Jonas Frisén, Kirsty L. Spalding. A mathematical model for the interpretation of nuclear bomb test derived 14C incorporation in biological systems. Nuclear Instruments and Methods in Physics Research Section B: Beam Interactions with Materials and Atoms, 2010, 268 (7-8), pp.1295-1298. ⟨10.1016/j.nimb.2009.10.156⟩. ⟨hal-00544517v2⟩
512 Consultations
2510 Téléchargements
